Hi everyone,
On Dashboard, I am adding a gadget to get status of story/bug based on component. I want the status to be display in a particular order, not randomly. Is it possible to achieve in JIRA cloud?
It is showing open -> Ready for QA -> Ready for development ...., instead the correct order should be (as per our workflow): Open -> Ready for Development -> Dev in progress ->Review in progress -> Ready for QA ...
You have the Sort Direction in the widget which you can choose
This Order is taken from the Configuration of the Administration
It affects all the Dashboard widgets across the instance.
Pramodh
I´ve same issue in a Jira Work Management and Team Managed project and can´t find the respective settings there. Can you guide how to do on that product and project type?
Many Thanks in advance
Register now
