Basic Auth JIRA's Rest API ( with SSO enabled)
David Frager May 7, 2018
We recently moved to JIRA Cloud, with SSO enabled via OneLogin.
Any attempt to authenticate, using an SSO account, via the REST API fails.  Our only work-around is to create an Internal JIRA account.
I have seen several posts on this, but I have not seen a clear solution.  We want to avoid having to maintain these "special" accounts, just for running scripts.
Claudiu Lionte
June 18, 2018
Hi David,
Did you try generating an API token? You can create as many as you want and revoke them at any time. Please see:
https://confluence.atlassian.com/cloud/api-tokens-938839638.html
Claudiu
David Frager June 23, 2018
the API Tokens do work, however, the physical device being used to connect is not constant, and having everyone remember their own token is not workable
Like • Carmine Elia likes this
Veda Sri April 28, 2019
Hi David,
Have you find a solution for this? How to authenticate jira API with SSO enabled?
Daniel Serodio
Veda, you need to generate the API token like Claidiu instructed, and use your SSO login (eg. firstname.lastname@example.com) as the username and the API token as the password.
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
