Bearer token based authentication in JIRA-Python API
abhay October 9, 2024
I am trying to use jira python library to initialise JIRA object using bearer token based authentication. I didn't find anything in the documentation.
Evgenii
Hi, @abhay
In my python script, when I connect to Jira, I use next code:
# Load environment variables from .env file
jira_base_url = config("JIRA_BASE_URL")
jira_api_token = config("JIRA_API_TOKEN")
jira_api_email = config("JIRA_API_EMAIL")
# Jira API endpoint for searching issues
jira_api_url = f"{jira_base_url}/rest/api/3/search"
base64_credentials = base64.b64encode(
f"{jira_api_email}:{jira_api_token}".encode()
).decode()
headers = {
"Authorization": f"Basic {base64_credentials}",
"Content-Type": "application/json",
Example of function, which I use to get issues by JQL query
def get_jira_issues(query, max_results=50):
issues = []
start_at = 0
while True:
params = {
"jql": query,
"fields": ["comment"],
"startAt": start_at,
"maxResults": max_results,
response = requests.get(jira_api_url, headers=headers, params=params)
if response.status_code == 200:
data = response.json()
issues.extend(data["issues"])
# Check if there are more issues to fetch
total = data["total"]
start_at += max_results
if start_at >= total:
break
else:
logger.error(f"Error fetching Jira issues: {response.text}")
raise Exception(f"Error fetching Jira issues: {response.text}")
return issues
Evgenii
As an alternative variant you can use python library to work with Jira
It's  atlassian-python-api library, that can work with different products
https://atlassian-python-api.readthedocs.io/
from atlassian import Jira
jira = Jira(url = "https://jira_url/", token = jira_token)
Like • abhay likes this
abhay October 29, 2024
Like • Evgenii likes this
abhay October 29, 2024 edited
Hey @Evgenii thanks for the reply
So you are using the requests library directly. I was asking with respect to jira pypi library in particular. Although I found a way to do it:
headers = {{
    "Accept": "application/json",
"Authorization": f'Bearer {{auth["accessToken"]}}',
jira = JIRA(
server=auth["url"],
options={{'server': auth["url"]}}
jira._session.headers.update(headers)
Read the story
