Behavior to limit character length and value in a custom text field
Scott Federman
Hey all,
I'm sure this is pretty easy but I'm pretty clueless with scripting. Could someone help me with a behavior that would only allow 2 characters and values of 0-25? Custom Field ID is 11850.
3 accepted
Hana Kučerová
Hi @Scott Federman ,
which type does your custom field have? Is it a Number Field or Text Field (single line)? Thank you.
Scott Federman
Hi @Hana Kučerová  its a text field...although i can change it to a number field if need be.
Hana Kučerová
November 10, 2020 edited
Hi @Scott Federman
the field's type is ok :-).
import com.onresolve.jira.groovy.user.FormField
FormField formField = getFieldById(getFieldChanged())
String value = formField.getValue() as String
if (!value.matches("[0-9]|1[0-9]|2[0-5]")) {
formField.setError("Your error message")
} else {
formField.clearError()
 Please add it as a server-side script to your customfield and try :-).
Scott Federman
November 11, 2020 edited
 @Hana Kučerová Its close! Its not allowing me to put any number in there at all though.
Scott Federman
@Hana Kučerová i did notice one other problem. It works great on the edit screen, but there is no restriction from the view screen which is allowing me to put any number in the fields via inline editing.
Hana Kučerová
@Scott Federman Please check the mapping (issue types, projects) and configuration of your Behaviour. Field's inline edit should not be not possible, when there's a validator, and Jira should automatically open the full edit screen, when you click on the pencil icon.
Scott Federman
Interesting. You are correct. I'm not sure what was going on earlier.
Hana Kučerová
Hi @Scott Federman
did you try to move to another field, after you've entered the correct value (like 14)?
Scott Federman
@Hana Kučerová ive tried moving to the next field as well as editing and have had no luck
Hana Kučerová
Please try to test this code:
if (value) {
if (value != "test") {
formField.setError("error")
} else {
} else {
Then it should work like this:
  • Field is empty -> ok
  • Field is filled with some random text -> error
  • Field is filled with word test -> ok
Each time you change the value of the field, move to the next field. Then the validator should be called (you can check in browser's console - there should be activity on the Network tab)
Maybe there is something wrong with the regex, but it works for me :-(...
Which version of Jira and ScriptRunner do you have?
Scott Federman
@Hana Kučerová here are my results
  • If empty then i can update the ticket
  • "Error" and error pops saying "Error" is not a valid number
  • "Ok an error pops saying  "Ok" is not a valid number.
  • Change to a number and it still says "Ok" is not a valid number.
We are using Jira 8.4.1 and scriptrunner 5.6.6.1-jira8
Hana Kučerová
@Scott Federman It seems to me, that your custom field must have Number Field type (not Text Field (single line)). Is it possible?
Are there any other behaviours defined for your project?
Thanks.
Scott Federman
@Hana Kučerová You know i could have sworn they were text fields but you are correct. They are number fields.
Hana Kučerová
@Scott Federman Thing happens :-)...
If it is a number, what about the values like 14.0 ? Are they valid or not? And what about 14.5? Thanks...
Scott Federman
Thanks @Hana Kučerová
No need for decimals. Everything will be a whole number.
Hana Kučerová
@Scott Federman Last try :-)
String value = formField.getFormValue() as String
if (value) {
} else {
} else {
Scott Federman
We have a winner!!!!
Thank you for everything @Hana Kučerová You are a magician.
Tomáš Doležel October 18, 2021
Hello @Hana Kučerová
I am also rookie in scripting. I spent hours of time to change if condition for custom field but didn´t find working solution. My condition should be:
Value of the custom field must contain exact 7 digits (not less, not more, only digits not letters).
Could you help me with this condition please? Thank you very much.
Hemanth Kumar September 22, 2022
@[deleted]  first of all, thanks for the attempts and patience. Can you please help me understanding below line ?
 I need to set the limit of an field to accept value only if its between (60 - 8400), this is numeric field these are values in seconds
Hemanth Kumar September 26, 2022
@Hana Kučerová I was able to create script with some help of google/community and figured out to ranging from 60 to 100, but can you assist how to fix the range to 3 digit and 4 digit value. (as mentioned in above - 60 - 8400 is my requirement)
if (value) {
    if (!value.matches("[6-9][0-9]|100")) {
        formField.setError("value should be bet. 60-8400")
    } else {
} else {
Hana Kučerová
@Hemanth Kumar
Please try:
(6[0-9]|[7-9][0-9]|[1-9][0-9]{2}|[1-7][0-9]{3}|8[0-3][0-9]{2}|8400)
@Hana Kučerová  It worked thanks a lot. But i would like to understand the format styling please.
I tried (("[6-9][0-9]|100") && ("[0-9][0-9][0-9]|1000")) assuming - 60 to 100 and 101 to 1000, but it didn't worked.
Hana Kučerová
@Hemanth Kumar
6[0-9] .. 60 - 69
[7-9][0-9] .. 70 - 99
[1-9][0-9]{2} .. 100 - 999
[1-7][0-9]{3} .. 1000 - 7999
8[0-3][0-9]{2} .. 8000 - 8399
8400 .. 8400
Like Hemanth Kumar likes this
@Hana Kučerová  thanks a lot, it helped
Kishore D
Hi @Hana Kučerová ,
Thanks for your script. it worked for me too.
Along with this script, i have extended requirement ie; my text field should not exceed more than 10 characters and it should allow only 0-9 numbers.
Help required from you:
if (!value.matches("[0-9]{1,256}")) {
} else {
 can you tell us how can we add "|" as multiple value separator.
[0-9]{1,256} is to keep field max length  is 256 characters. we need to modify script as to add "|" as multiple value separator.
Expected:
Field_name= 1234|456|7890|..
can you help?
Venkat.Suresh February 16, 2024
@Hana Kučerová My requirement is in the Numeric field type (Data Center) value has to be between 00000 and 99999. Using https://3widgets.com/, I got the expression as
(0{4}[0-9]|0{3}[1-9][0-9]|00[1-9][0-9]{2}|0[1-9][0-9]{3}|[1-9][0-9]{4})
Wrote the below Behavior on the field as below and it does not work (accepts decimals, more than 5 characters etc)
if (value) {
    if (!value.matches("(0{4}[0-9]|0{3}[1-9][0-9]|00[1-9][0-9]{2}|0[1-9][0-9]{3}|[1-9][0-9]{4})") {
        formField.setError("value should be bet. 00000-99999")
    } else {
} else {
Any suggestions on where I am going wrong?
Hana Kučerová
February 18, 2024 edited
@Venkat.Suresh Maybe
[0-9]{5}
?  But you probably need to change it to the text field because of the leading zeros.
Venkat.Suresh February 19, 2024
@Hana Kučerová Even after changing to Text field type, below behavior does not error when entered characters.
Character field validations
if (value) {
if (!value.matches("(0{4}[0-9]|0{3}[1-9][0-9]|00[1-9][0-9]{2}|0[1-9][0-9]{3}|[1-9][0-9]{4}|[0-9]{5})") {
} else {
} else {
Any other ideas? or pointers?
Hana Kučerová
@Venkat.Suresh Have you tried
[0-9]{5}
instead of
@Hana Kučerová Thank you for the response so far.
Tried as below on a Character field
if (value) {
    if (!value.matches("[0-9]{5}") {
    } else {
} else {
No luck. Something is wrong.
But on a Number type of field tried as below and is working. But since 00013 is an allowed value and having a number field will reduce value to 13 instead of retaining as 00013, I have to have it as a Character field
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
@BaseScript FieldBehaviours fieldBehaviours
def XSMClarityID = getFieldById(getFieldChanged())
def FieldValue = XSMClarityID.getValue() as Long;
if (FieldValue.toString().length() < 5)
    XSMClarityID.setError("ID Value must be 5 digits")
}else
if(FieldValue < 0 || FieldValue > 99999 )
    XSMClarityID.setError("ID Value must be between 00000-99999")
}else
    XSMClarityID.clearError();
Venkat.Suresh February 27, 2024 edited
Finally figured the solution on a text field
import java.lang.String
def field = getFieldByName("Custom Field name")
if ((field?.value as String)?.length() > 5 || (field?.value as String)?.length() < 5 || (field?.value as String)?.contains(".") || !(field?.value as String)?.isNumber()) {
field.setError("Value should be exactly 5 numbers between 00000 to 99999. No Decimals or alphabets allowed")
} else {
field.clearError()
Peter Preston
November 16, 2020
@Scott Federman - glad you were able to resolve the validation problem. If this is something you need to build often, you could try ProForma (or ProForma Lite - a free version of the app) for a simpler way to build validation. Full disclosure, I'm on the ProForma team.
