Behaviours error after migration JIRA server 8.5
BYA January 13, 2021
we migrated from JIRA 7 to 8.5.
Now I have errors with a behavior that work great before migration.
import com.atlassian.crowd.embedded.api.User
import com.atlassian.jira.component.pico.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
ComponentManager componentManager = ComponentManager.getInstance()
Object fieldID = getFieldById("Application")
MutableIssue currentIssue = componentManager.getIssueManager().getIssueObject(Long.parseLong(fieldID.value))
FormField pr_field = getFieldById("Application")
def isPR = componentManager.getUserUtil().getGroupNamesForUser(currentIssue.getReporter
User().getDisplayName()).contains("Groupe-P2B-Application_2")
if(!isPR){
pr_field.setHidden(false)
pr_field.setRequired(true)
 help please ?
BR
Fayçal
Dirk Ronsmans
January 13, 2021
And what exactly is the error?
Also what version of scriptrunner did you upgrade from and to?
this a screen shot of this error :
ScriptRunner from V 5.6.12  to V 6.16.0.
Thanks for your help.
BR
Dirk Ronsmans
January 13, 2021
Can you try adding the explicit import?
import com.onresolve.jira.groovy.user.FormField
i put this code in the behaviour :
import com.onresolve.jira.groovy.user.FormFieldComponentManager
def isPR = componentManager.getUserUtil().getGroupNamesForUser(currentIssue.getReporterUser().getDisplayName()).contains("Groupe-P2B-Application_2")
if(!isPR){
 now i have this error :
Sans titre.pngplease help ?
Fayçal
Dirk Ronsmans
January 13, 2021
Well you didn't import the correct class..
is not
I m sorry for the mistake :
if(!isPR){
i have also this error :
Sans titre.pngThanks for your help
Fayçal
Dirk Ronsmans
January 13, 2021
Well I don't see anything wrong with that line of code.
I also don't find anything in the release notes that might be causing this for v6.x
Might be best to simply raise a call with Adaptavist for this to see if anything in the classes has changed that wasn't mentioned in the release notes.
Or hope for someone else to take a look and see whats wrong..
I hope so too.
Thank you for taking the time to help me
