Best Approach for Integrating Two Jira Cloud Instance
Vikrant Yadav
Hi Experts,
Kindly help me with integrating two jira cloud instance.
What would be the best approach and best practise for integrating two jira cloud ?
We don't have any plugin like BB sync or Exalate for two way sync.
Diana_Architect_ZigiWave
@Vikrant Yadav hello. Diana from ZigiOps' team here. There are two primary approaches to integrating two Jira Cloud instances: using a third-party integration platform like ZigiOps (you can find it in the Atlassian marketplace) or leveraging native Jira Cloud integration features. Here's a breakdown of both methods:
1. Integration Using ZigiOps (Third-Party Integration Platform)
Best Approach in the case:
  • Seamless Integration: ZigiOps provides a flexible, scalable solution for connecting two Jira Cloud instances. It allows for bi-directional synchronization of issues, projects, and workflows across instances.
  • Customizable Field Mapping: With ZigiOps, you can map custom fields, issue types, and statuses to ensure that data flows consistently and accurately between the two Jira instances.
  • Automated Workflows: You can automate processes like issue creation, status changes, and updates across both instances, minimizing manual effort and reducing errors.
  • Real-Time Sync: ZigiOps ensures real-time synchronization, meaning any updates in one instance are reflected in the other immediately, improving collaboration and data consistency.
  • Security and Permissions: The platform respects user permissions in both Jira instances, ensuring data security and access control.
If you're interested, book a free demo with our team to see ZigiOps' capabilities or try our free trial (and test it yourself)
2. No Third-Party Tools
Best Approach in your case:
  • Jira Cloud REST API: Use Jira's built-in REST API to integrate two Jira Cloud instances. This requires custom development to connect the two instances, create synchronization rules, and handle data flow. The API allows you to create, read, and update issues across both instances programmatically.
  • Webhooks: Set up Jira webhooks to trigger actions in one instance when changes occur in the other. This allows for near-real-time data updates and can help automate issue syncing.
  • Custom Scripts or Automation: Leverage Jira Cloud Automation rules to sync data, like creating issues in one instance when they’re created in the other or updating issue statuses based on triggers.
Christophe De Beule
Hi @Vikrant Yadav
I am Christophe from Exalate.
With Exalate you can easily intigrate your 2 Jira's.
The solution boasts a unique, decentralized approach to integrating various work systems together while providing full autonomy to each side of the connection.
Using this full autonomy, you can easily send your tickets from one Jira to the other one.
you can use Exalate for a bi & uni-directional synchronization, you decide which fields and values you send and receive.
Setting up Exalate is straightforward, and you can customize it to meet your exact needs.
If you would like to discuss your use case further or look at the product in action, please book a demo and we will be happy to assist further.
Christophe De Beule
Hi @Vikrant Yadav
Unless both the Jira cloud instances are administered by your org, another problem with plug-ins is they typically require admin access and enabling user email public visibility, which are huge security risks for enterprises..
Other problems with plugins are:
  • Excess coding – you will have to almost code whole sync to integrate comments, attachments, links, formatted content, conflict. Literally everything requires coding.
  • Webhooks are used extensively which are known to slow down Jira and miss updates randomly
  • Be careful with field matching—custom fields need to be mapped 1:1 and field types must be compatible.
 OpsHub Integration Manager, an Atlassian Silver Solutions Partner can help here if you want a plugin-free option that’s more structured. It supports:
  • Two-way sync between Jira instances without installing apps, without any coding
  • Field-level mapping, comment transfer, and status updates – again no coding required
  • Clean audit trails and traceability without breaking Jira’s native UX – again no coding :)
Tushar Khandelwal April 30, 2025
Hi @Vikrant Yadav ,
I also wanted to integrate my 2 Jira cloud instances. As I have seen your answers above. So, what is the best solution you have applied for it? and any challenges you have faced in integrating 2 cloud instances? Could you suggest me so that i also can go through the same way
Mathieu Lepoutre _Exalate_
Dear @Vikrant Yadav  I work with Exalate
For a robust two-way sync between Jira Cloud instances, you might want to consider using a solution like Exalate. It allows flexible, bi-directional integration and supports advanced use cases.
Bogna Krystian_Deviniti_
Hi @Vikrant Yadav
Issue Sync Pro , developed by the company I work for, enables integration between two (or more) Jira Cloud instances.
It provides:
Two-way or one-way synchronization of issues across different Jira Cloud instances.
Sync of fields, comments, attachments, statuses, custom fields, and more.
Full control over mapping, triggers, and scope of what gets synced.
This is a link to Issue Sync Pro Support Center , where you can see the app's demo, documentation and more in one place
Mathew Lederman
March 18, 2025
@Vikrant Yadav I'm curious, have you tried Copy Jira data?
Vikrant Yadav
@Mathew Lederman  Copy Data doesn't work in my case.
Both Jira Instance have different admin and owned by different organization.
We need to setup a two way sync, copy data is just a one time copy data to another instance.
