My client plans to use Jira for HW test case management & HW bug management. The client works with large number of external vendors on testing.
My client's scenario: They have let's say 100 HW test cases defined for a project. They...
What is the recommendation for setting up projects and permissions for this scenario?
Thanks all for any insights you can provide.
Kalindi
There are no field security restrictions (I’m sure there is an app that will solve it) so if you can see an issue you can see everything.
However... there is Issue Security schemes. That would you to have the choice of opening up issues to internal only, internal+vendorA, vendorA only, internal+vendorB etc.
For more about issue security schemes - see https://confluence.atlassian.com/adminjiracloud/configuring-issue-level-security-776636711.html
