I work for a small hardware development company that would like to move forward with Jira and associated 3rd party apps for work management, waterfall project managment (replacing MS Project), time tracking and capacity planning for approximately 40 engineers. Jira Premium with a timesheet app appears to check most of the boxes. I am looking for a reference on how to best set up plans and projects. For example, how to best organize issues for engineering work related to sales, production, installations and product improvements across multiple products lines being addressed by multiple teams. One big project with thoughtful use of components, categories and labels? Or smaller projects rolling up to a plan? Are there consultants that provide this type of setup guidance? I think this effort is too small for the consulting companies listed as Atlassians Partners. Any advice would be greatly appreciated.
Yes, there are two main approaches you can consider:
One Big Project with Components:
Smaller Projects Rolling Up to a Plan:
Recommendation:
For 40 engineers and multiple product lines, a hybrid approach might be best. Start with a Plan outlining your overall product development strategy. Within the plan, create separate projects for each product line or phase (sales, production, installation) with relevant components and labels for further organization.
Additional Considerations:
HTH,
KGM
I hope this gets the ball rollin'. Lot of the decisions that need to be made also depend on what the preference is so it is hard to give an exact answer.
Best, KGM
Thank you for thoughtful response! Your advice is very helpful.
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
