Hi Community,
I tried to search through this across web but couldn't find any justifying answer. How do you manage test cases in JIRA?
Suppose I have 500 test cases for a single story, how should I do it? Do I need to create 500 subtasks in that story for each individual test case?
Also I need to show how many test cases are created for a specific story? How many of them executed successfully and how many of them failed? Is there a way to visually show this data by use of any app?
Basically for e.g.:
User story 1:
No of test cases: 100
Successfully executed: 50
Failed: 50
Pass percentage: 50%
Is there a way I can represent such data in dashboard form. Please help!
What @Dick suggested is definitely doable and an approach to use if you don't plan to use any plugins. But in the long term, this approach may not be scalable since testers may forget to write down numbers or update the relevant fields in Jira.
A test management app will help you keep track of passes and failures and defects, all in one place, without needing to run after folks to ensure their data is timely updated.
You can try using AIO Tests. It has a very intuitive interface, zero setup for a quick start. It's a plug-and-play app.
You can create cases manually, via AI (just specify the story), as well as import via Excel and then you can run Traceability reports (Summary and Detailed) to see pass/failure %age against each story in the release.
This is a sample view of AIO Tests panel from the Jira story providing visibility from a traceability as well as execution perspective.
We will be glad to give you a demo to showcase all the capabilities of AIO Tests. Please reach out to us via help@aiotests.com or book a session from our calendar.
Noopur (AIO Team)
Let the tester keep track on his notebook and report the number of tests and the fails into two separate numeric custom fields. You can have a third custom field with the percentage passed. that can be filled using math expressions (standard in Jira, no need for plug-ins here).
A nice read to get up to speed with math in Jira: Jira smart values - math expressions | Cloud automation Cloud | Atlassian Support
I think that our application QAlity Plus - Test Management for Jira might be useful for your use case.
Our Test Cases are another type of the Jira issue with additional function of the Test Management for writing your test steps. Because of that you can create as many test cases as you want under the specific Jira Story.
What's more, the Test Cases you've already created can be easily linked to your Jira Story.
You can also track your Stories and linked Test Cases by using the Traceability Report. You will find there what test cases are linked, statuses of their execution and reported bugs during execution.
There are many more useful features in the app. If you have any questions then go ahead and let us know here, or if you prefer, we would be happy to meet with you to present a demo - link.
Michał
SolDevelo Team
Hi Vishal,
I highly recommend considering the QTM4J (QMetry Test Management for Jira) app for your test management needs. QTM4J stands out in the Atlassian ecosystem as it provides comprehensive test management capabilities, along with exceptional traceability, making it the best value-based test management app available.
With QTM4J, you'll benefit from advanced AI features including Auto Test Case Generation, Flaky Score, and AI Search. These tools are designed to enhance productivity while also reducing costs. I encourage you to schedule a quick demo with us to explore how QTM4J can improve your testing process.
Brijesh Patel.
No plugin. Currently team is doing in excel and uploading the same. Do you have nay preference?
@Vishal Gogari If you don't have any plugin, just want to show passed vs failed Percent on dashboard, then @Dick solution works for you.
In my organization, we are using Zephyr Scale for Test management.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
