  • Community
  • Q&A
  • Jira
  • Questions
  • Best way to import JIRA Agile and JIRA Service Desk projects from seperate Jira Cloud instances
Dennis Worsham March 24, 2015
We are in the process of merging projects from two instances of JIRA cloud.  Unfortunately the projects we care about are JIRA Agile and JIRA Service Desk projects, so we can't do a project import or merge (unless someone can point me to how this can be done).  What this means is that we need to import users, groups, workflows, etc from one to the other.  Does anyone have any suggestion on how to go about doing this?
Shawn C
March 24, 2015
Hello Dennis,
Unfortunately there is no easy way to merge separate cloud instances together.  There is a Feature Request (https://jira.atlassian.com/browse/JRA-40464) to add the ability to perform Project Imports within the Cloud.
Since Project Import does not exist in the cloud, you will need to leverage 2 Behind the Firewall Servers to clone your Cloud Instances to.  In a nutshell, once you have your BTF 'Clones,' you would be able to Project Import one of the BTF Servers to the Other.  Once consolidated, you could then export the BTF Server back to the Cloud.
Detailed steps can be found at: https://confluence.atlassian.com/display/CLOUDKB/How+to+Merge+Two+JIRA+Cloud+Instances
-shawn
Jobin Kuruvilla [Adaptavist]
March 24, 2015
I am afraid you will have to do some scripting for one of the instances. There is no ready made solution for it.
We have done this for some customers and it is a bit more complicated than it appears. Especially because if the changes in ids in the target environment.
