BitBucket does not launch when installed in the same Server as Jira
Hyd3k
When I try to run the Bitbucket launcher I get following error:
Exception in thread "main" BindHttpException[Failed to bind to [7992]]; nested: ChannelException[Failed to bind to: /0:0:0:0:0:0:0:1%lo:7992]; nested: BindException[Address already in use];
Likely root cause: java.net.BindException: Address already in use
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Net.java:433)
at sun.nio.ch.Net.bind(Net.java:425)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
at org.jboss.netty.channel.socket.nio.NioServerBoss$RegisterTask.run(NioServerBoss.java:193)
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.processTaskQueue(AbstractNioSelector.java:391)
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:315)
at org.jboss.netty.channel.socket.nio.NioServerBoss.run(NioServerBoss.java:42)
at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Refer to the log for complete error details.
Gonchik Tsymzhitov
Hi!
1.
"ChannelException[Failed to bind to: /0:0:0:0:0:0:0:1%lo:7992]; nested: BindException[Address already in use];"
just check which soft used this port. for check you can use like this command:
netstat -anpt | grep 7992
2. review your bitbucket.properties
If you need to change ports just use this doc
https://confluence.atlassian.com/bitbucketserver/bitbucket-server-config-properties-776640155.html
Gonchik Tsymzhitov
Hyd3k
My system is:
CentOS 7 x64, 9GB RAM, 200GB hard disk.
Jira Software 7.5 x64.
I tried installing Bitbucket 5.4 but unable to make it run while Jira Software is running.
Any advice?
