Block parent issue to transition to done until all child issue status done
İclal Aslan
Shalini Pradhan
July 28, 2025
Hello @İclal Aslan ,
Good day! Welcome to Atlassian community :)
In order to block parent issue to transition to done until all child issue status done, you can achieve this with a workflow transition Condition called "Sub-task Blocking Condition". It is a condition to block parent work item transition depending on sub-task status.
Thank you!
İclal Aslan
Thank you so so much :) is there a way to do it with validator so that people can see the transition but see the error. Otherwise they'll keep asking why they don't see the transition :D
Shalini Pradhan
July 28, 2025
@İclal Aslan Unfortunately, we dont have any options in validators to achieve this configuration.
İclal Aslan
Thank you! but I thşnk sub task condiiton won't work for Epic right?
Maciej Dudziak _Forgappify_
Hi @İclal Aslan, no it won't work, to make it work, you will need 3rd party validator or create some workaround with automation that would revert the transition
İclal Aslan
Hi thank you so much!
I have JMWE and using this(below) Issue Link Type : belongs to Epic wont work do you have any ides of this?jmwe.png
Since some time the Epic Link has been replaced in Jira by parent field. Is there a Parent option? Maybe check that
