Block the transition if the fixversion contain "backlog" in its name
Rahma Ajengui January 5, 2024
I need to add a validation rule in the workflow to block th transition if the Fix Version contain "Backlog" in its name for example "Backlog 2.4" .
I find this expression !!issue.fixVersions && issue.fixVersions.some(it => it.name != "backlog")
But I did not find how can say doesn't include "Backlog"
Kavitha Chandrasekaran
January 5, 2024
Natively, there are two options. Not 100% solution, but close
1) Adding a condition to workflow transition. This doesn't have contains comparison. So bit restrictive.
2) Add an automation rule and include all fixversions that should not transition. This will involve updating the rule whenever you add a new fix version that contains backlog. In the example, I added two fix versions "backlog" and "Test backlog"
Screen Shot 2024-01-05 at 11.53.29 pm.pngScreen Shot 2024-01-05 at 11.50.41 pm.png
Rahma Ajengui January 8, 2024
I will try the automation rule thank you!
Dan Tombs
Hi @Rahma AJENGUI can you please advise if you are trying to do this with any apps or through native functionality?
I am trying to create a rule with JMWE on jira software.
