×You used to edit quick filters in board settings, but in the new look, the only options I see in board settings are the "General settings", which does not include quick filters - along with other settings, like swim lanes.
The screen ends after "filter details".
I am an admin on the project; I was configuring this only recently.
Hello @Michael Betts
With the new navigation screen you can get to the board configuration by clicking the ... button next to the board name.
If you then expand the Layout option in the navigation panel on the left, you will find the link for Quick Filters.
I think this is correct; though in my instance, at least, some kind of bug is not updating the navigation panel on the left with the board options.
Ah, yes, I see what you mean.
The repainting of the navigation panel does not appear to be consistent. Whether I select the Board Setting from the navigation panel or from the button next to the board name above the board, sometimes the navigation panel did not change. I would have to refresh the page and then the Board Settings options would display on the left.
Seems like a bug. I was able to find the screens by selecting Board settings, then again selecting Board settings from the sidebar.
It is not a bug. It is the new navigation, as I mentioned in my reply.
You can get to the board settings from the three-dots button next to the board name above the board, as I mentioned, and from the three-dots button next to the board name in the new navigation panel on the left.
hi @Michael Betts - Welcome to the Atlassian Community. For context, how are you reaching at this page? Can you please open the board and then on the right hand side you should see "..." and from there you can click on "Configure board" as shown below -
Once you open that you should see "Quick filters" and "swimlanes" below the general tab.
Please let me know if this helps.
Bharat
I do not have that option. I can only find the screenshot from my original post by selecting the Board settings next to the board title.
