Bug Removes Calendar Entries Silently
Rudolf Vaum
July 21, 2015
Hi there,
We bought your Work Calendar for our local server and we also use it on cloud.
We have an issue with the cloud version - every 2-3 days an item logged earlier disappears.
This happens under this account/URL: https://lucidcx.atlassian.net/plugins/servlet/ac/my_work_calendar/calendar-page?project.key=UAD&project.id=10300 for the user jozsef.sas
How can we prevent this?
Rudi Vaum
lavitz slambert
July 24, 2015
I thought you meant team calendar and not work calendar.. facepalm me...
Yep, we might need to wait for the dev for assistance. In case he need logs to better understand this then you will need to reach atlassian support for the logs.
Sorry about that buddy smile.
Thanks and Regards,
Lavitz - the guy that uses Confluence on Windows as a Hobby!
Rudolf Vaum
July 24, 2015
Hi Lavitz,
If I understand correctly this addon is directly supported by the developer and this is the right place to get in touch with him?
lavitz slambert
July 23, 2015
Hey Rudi,
I would recommend you to raise a support case at https://support.atlassian.com so one of atlassian cloud engineer's can better review this problem as they have access to your calendar and logs smile.
Thanks and Regards,
