Bug: Update to Jira 8 broke all Agile board and comment issues
Xarkam February 12, 2019 edited
I proceeded to update Jira into Jira 8.
All my Agile kanban board is broken with this stack trace:
An error occurred
Please try refreshing the page, or contact your administrator / Atlassian Support if the problem continues.
Details
Exception: Uncaught Error: Syntax error, unrecognized expression: .#ac-wrapper .gl-ui-textarea-cancel
Resource: https://issues.osames.org/s/dadc804a35392c748cd110275650e3c7-CDN/62dbm3/800007/b470ce35634c35ab5fa1e355a0c98c03/bfbcaa85c5e2041247e0b5f2890ae185/_/download/contextbatch/js/_super/batch.js?locale=en-UK
Line: 65
Column: 8302
Line: 65
Column: 8302
Line: 65
Column: 8302
Environment
Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.96 Safari/537.36
Stack trace
at Function.re.error (https://issues.osames.org/s/dadc804a35392c748cd110275650e3c7-CDN/62dbm3/800007/b470ce35634c35ab5fa1e355a0c98c03/bfbcaa85c5e2041247e0b5f2890ae185/_/download/contextbatch/js/_super/batch.js?locale=en-UK:65:8308)
at re.tokenize (https://issues.osames.org/s/dadc804a35392c748cd110275650e3c7-CDN/62dbm3/800007/b470ce35634c35ab5fa1e355a0c98c03/bfbcaa85c5e2041247e0b5f2890ae185/_/download/contextbatch/js/_super/batch.js?locale=en-UK:65:16271)
at re.compile (https://issues.osames.org/s/dadc804a35392c748cd110275650e3c7-CDN/62dbm3/800007/b470ce35634c35ab5fa1e355a0c98c03/bfbcaa85c5e2041247e0b5f2890ae185/_/download/contextbatch/js/_super/batch.js?locale=en-UK:65:16378)
at re.select (https://issues.osames.org/s/dadc804a35392c748cd110275650e3c7-CDN/62dbm3/800007/b470ce35634c35ab5fa1e355a0c98c03/bfbcaa85c5e2041247e0b5f2890ae185/_/download/contextbatch/js/_super/batch.js?locale=en-UK:65:17620)
at Function.re (https://issues.osames.org/s/dadc804a35392c748cd110275650e3c7-CDN/62dbm3/800007/b470ce35634c35ab5fa1e355a0c98c03/bfbcaa85c5e2041247e0b5f2890ae185/_/download/contextbatch/js/_super/batch.js?locale=en-UK:65:2951)
at Function.c.find (https://issues.osames.org/s/dadc804a35392c748cd110275650e3c7-CDN/62dbm3/800007/b470ce35634c35ab5fa1e355a0c98c03/bfbcaa85c5e2041247e0b5f2890ae185/_/download/contextbatch/js/_super/batch.js?locale=en-UK:83:1259)
at HTMLDocument.handlers (https://issues.osames.org/s/dadc804a35392c748cd110275650e3c7-CDN/62dbm3/800007/b470ce35634c35ab5fa1e355a0c98c03/bfbcaa85c5e2041247e0b5f2890ae185/_/download/contextbatch/js/_super/batch.js?locale=en-UK:65:35593)
at HTMLDocument.dispatch (https://issues.osames.org/s/dadc804a35392c748cd110275650e3c7-CDN/62dbm3/800007/b470ce35634c35ab5fa1e355a0c98c03/bfbcaa85c5e2041247e0b5f2890ae185/_/download/contextbatch/js/_super/batch.js?locale=en-UK:65:34835)
at HTMLDocument.v.handle (https://issues.osames.org/s/dadc804a35392c748cd110275650e3c7-CDN/62dbm3/800007/b470ce35634c35ab5fa1e355a0c98c03/bfbcaa85c5e2041247e0b5f2890ae185/_/download/contextbatch/js/_super/batch.js?locale=en-UK:65:33212)
This broke whole kanban page. Including Jira Navigation bar.
Checked with Chrome/Firefox and no browser cache.
Edit: comments for issues is also affected by this bug. New page is opened for commenting instead of add after the comments list
Xarkam February 13, 2019
I removed very old plugins in folder ./application-data/jira/plugins/installed-plugins
-rw------- 1 jira jira 312K May 03 2018 10:45:30 acceptancecriteria-3.2.2.jar
-rw------- 1 jira jira 4.4M Dec 09 2016 20:34:43 base-hipchat-integration-plugin-7.8.29.jar
-rw------- 1 jira jira 1.1M Dec 09 2016 20:34:43 base-hipchat-integration-plugin-api-7.8.29.jar
-rw------- 1 jira jira 3.9M Dec 09 2016 20:34:43 hipchat-for-jira-plugin-7.8.29.jar
-rw------- 1 jira jira 4.1M Jun 11 2018 16:45:11 je-3.6.4.jar
-rw------- 1 jira jira 7.8M Apr 25 2018 13:23:06 plugin_1682675826645144253_atlassian-universal-plugin-manager-plugin-2.22.9.jar
-rw------- 1 jira jira 7.7M Aug 07 2017 14:45:05 plugin.2748261022094058553.atlassian-universal-plugin-manager-plugin-2.22.4.jar
-rw------- 1 jira jira 315K Mar 17 2016 17:02:58 plugin.4115449260960286045.jira-importers-asana-plugin-1.0.5.jar
-rw------- 1 jira jira 2.6M Jan 09 2018 11:50:11 plugin_6943473997674594374_plugin-jira-1.8.4.jar
-rw------- 1 jira jira 2.7M May 22 2018 13:11:09 plugin_8249651359643682378_plugin-jira-1.10.3.jar
One of this make the error.
Why do I still have very old jira plugins in this folder?
Deleted user April 23, 2019 edited
Removing acceptancecriteria-3.2.2.jar worked for me.
Zbyněk Konečný
March 9, 2019
The plugin causing this is the acceptance criteria plugin.
Xarkam March 9, 2019
Thanks for your information :)
Bharath Kumar Kappala
June 5, 2019
@Zbyněk Konečný  We have a similar kind of problem where can I find the Acceptance criteria plug in ?
Like Eddie Razmos likes this
Zbyněk Konečný
June 5, 2019
Just follow the standard procedure for disabling apps:
https://confluence.atlassian.com/upm/disabling-and-enabling-apps-273875716.html
June 5, 2019
June 5, 2019
@Xarkam Could you please share the solution for this problem if you found any thanks.
Xarkam June 5, 2019
Please, look accepted answer tagged post.
June 5, 2019
Thank you
Gabriele Franck
February 12, 2019
Hey, xarkam
Did you perform the upgrade following the steps from Upgrading Jira applications?
Edit2: backlog is also affected.
Yes, absolutely.
I do not have also any addons in my instance of jira.
Maybe it's a remanence of an addon that I had put in the past?
I also looked at the logs on the server and devtools in my browser and I have no errors.
edit: css class is present in:
https://issues.osames.org/s/b052076d5cd7381233e3235f4cca9b75-CDN/g4j83p/800007/b470ce35634c35ab5fa1e355a0c98c03/5e2dc0f7f821d604ebee64018456c8b2/_/download/contextbatch/css/gh-rapid-work,jira.project.sidebar,atl.general,jira.global,com.atlassian.jira.projects.sidebar.init,greenhopper-rapid-non-gadget,-_super/batch.css?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&whisper-enabled=true
Each click on page make an error, but I can interact with links.
After investigating, the problem also affect issues new comments creation.
On create new comments, Jira redirect to new page for writing comments.
An javascript error appear on clicking comment button:
batch.js:65 Uncaught Error: Syntax error, unrecognized expression: .#ac-wrapper .gl-ui-textarea-cancel
at Function.re.error (VM1853 batch.js:65)
at re.tokenize (VM1853 batch.js:65)
at re.compile (VM1853 batch.js:65)
at re.select (VM1853 batch.js:65)
at Function.re (VM1853 batch.js:65)
at Function.c.find (VM1853 batch.js:83)
at HTMLDocument.handlers (VM1853 batch.js:65)
at HTMLDocument.dispatch (VM1853 batch.js:65)
at HTMLDocument.v.handle (VM1853 batch.js:65)
re.error @ VM1853 batch.js:65
re.tokenize @ VM1853 batch.js:65
re.compile @ VM1853 batch.js:65
re.select @ VM1853 batch.js:65
re @ VM1853 batch.js:65
c.find @ VM1853 batch.js:83
handlers @ VM1853 batch.js:65
dispatch @ VM1853 batch.js:65
v.handle @ VM1853 batch.js:65
@Gabriele Franck the mistake would be the . before # on #ac-wrapper class ?
Read the story
