Hi Team,
I have 2 different custom fields (Field A, Field B) in Jira datacenter. I was looking to build a new calculated custom field (Field C) where the values will be the sum-up of Field B on a specific JQL search.
Example: I have a JQL query "Field A = xx" this will return few issues. Now based on the results, I would like to sumup the values of 'Field B' and populate them on 'Field C'
same way I would like to add multiple conditions
I have a JQL query "Field A = yy" this will return few issues. Now based on the results, I would like to sumup the values of 'Field B' and populate them on 'Field C'
Is this possible to achieve?
Hi @_Uday Kiran
For your requirement, a Scripted Field is a straight forward approach.
Below is a sample code for your reference:-
import com.adaptavist.hapi.jira.issues.Issues
def jql = "'Number 1' > 10"
Issues.search(jql).collect {
it.getCustomFieldValue('Number 2') as Long
}.sum()
Please note that the sample code above is not 100% exact to your environment. Hence, you will need to make the required modifications.
Below is a screenshot of the Scripted Field configuration:-
I hope this helps to solve your question. :-)
Thank you and Kind regards,
Ram
Also, Can we include an another logic here?
Suppose user selects customfield A (Single-Select) value as 'A' on create or edit screen
Script should automatically make a JQL search as customfield_A = A and from the results calculate the values in customfield B (Number field) and display the sum in Customfield C (Scripted Field)
Same way should happen on everytime the user selects a value from customfield A.
Below script doesnt really work:
// Replace 'Customfield_A', 'Customfield_B', and 'Customfield_C' with actual field names or IDs
def customfieldAName = 'Customfield_A'
def customfieldBName = 'Customfield_B'
def customfieldCName = 'Customfield_C'
def issue = issue
def customfieldAValue = issue.getCustomFieldValue(ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName(customfieldAName))
if (customfieldAValue) {
def jql = "'${customfieldAName}' = '${customfieldAValue}'"
def totalSum = 0
def searchService = ComponentAccessor.getComponent(SearchService)
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def query = jqlQueryParser.parseQuery(jql)
def searchResults = searchService.search(ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser(), query, PagerFilter.getUnlimitedFilter())
searchResults.getResults().each { searchIssue ->
def customfieldBValue = searchIssue.getCustomFieldValue(ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName(customfieldBName)) as Long
totalSum += customfieldBValue ?: 0
issue.setCustomFieldValue(ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName(customfieldCName), totalSum)
Hello @_Uday Kiran
Yes, its possible with automation. You can have a scheduled rule which does this for you on daily basis and populate field C which I am guessing already exists.. You havent given any specifics so hard to go any further. Start with the rule and share some screenshots with actual fields and we can help.
Save your spot
