Bulk Change
Hazha.ahmed
Is it possible to select multiple or all Jira issues of a status(board) and change it to another status?
Please provide the steps.
Thank you.
2 accepted
3 votes
Trudy Claspill
Yes, this is possible, if you have sufficient permissions.
  • You need the Make Bulk Changes global permissions.
  • You need permissions within the relevant project to change the status of the issues, in general, and specifically whatever might be required if Conditions are set on the transition.
  • There must be a transition defined in the issue workflow supporting changing the status in the way you want.
  1. From the Advanced Issue Search screen create a search that retrieves the issue you want to change.
  2. Click on the ... button in the upper right corner and select Bulk Change All Issues
  3. Choose the issue you want to change and click Next.
  4. Choose Transition Issues and click Next
  5. Choose the Destination Status and click Next.
  6. Confirm you selections.
Note that there is no Undo/Revert option so make sure that you are very sure you want to change the issues.
Hazha.ahmed
Hi @Trudy Claspill
Thank you for the answer. However, that still creates a lot of notifications for the members involved in the project.
Is there any other way I can move bulk items inside the same project from one status to another?
Thanks again.
Trudy Claspill
If you are a Jira Administrator you should see this option to disable sending emails for your bulk change. If you are not a Jira Admin you own't have that option.
Hannes Obweger - JXL for Jira
March 7, 2023 edited
Hi @Hazha.ahmed
if you prefer a more interactive bulk-editing experience, you might like the app that my team is working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also supports spreadsheet-style bulk-editing via copy/paste, like so:
You can update any number of issues in one action, and also undo/redo, just like you would in any other app.
Best,
Hannes
Hazha.ahmed
Hi @Hannes Obweger - JXL for Jira
That's a cool tool. What about the notification? Does it still send a ton of notifications upon the changes made or just one notification?
Thank you.
Hi @Hazha.ahmed,
that's configurable on your sheet:
There's a few nuances to this, because of certain limitations that Jira has; put simply, you can only disable the notifications if you are an admin to the respective issue (that's the same limitation that Trudy mentioned wrt. Jira's built-in bulk editing wizard).
Best,
H
Hazha.ahmed
Makes sense.
Thanks again, @Hannes Obweger - JXL for Jira
Like • Hannes Obweger - JXL for Jira likes this
Parveen Vats
March 27, 2023 edited
Hi! Can we do a bulk change action in team-managed project ? I am not able to find the option ?
Kindly help
Parveen
Found it. Kindly ignore.
FREE
