×Hello,
Just noticed that the option to select multiple issues in the issue navigator has been removed for our site. As far as I can tell we did not alter any configurations that would impact this feature.
Does anyone know if this is a feature that can be toggled? If so, where is the config managed?
Atlassian ended up reaching out to me after I submitted a support ticket. Apparently, this is a new feature that was accidently enabled for our site early.
I still have the option in the Issue List from the project, so it could be your instance.
Hi Michael - Welcome to the Atlassian Community!
It is probably just a permission thing. If you are a Jira Admin, go to:
Settings > System > Global Permissions
Then check for who has the permissions for Make Bulk Changes
Hi John,
I should have included this in my original post, but I checked the global permissions and everything looks correct. The option to bulk edit from the right hand ... menu is available as well, just not the ability to perform it on the issue navigator.
Can you share a screenshot of where you think it should be but it is not? Also, what type of project is this? Company-managed? Team-managed? Software? Business?
