Bulk copy multi select custom field values to another multiselect field
jaya chandra reddy nellore September 14, 2023
I have two multiselect fields i want to bulk update issues from field 1 to field 2 with out updating history.
I have found below script in community but getting issue with that script.
Script:
import com.atlassian.jira.issue.customfields.manager.OptionsManager
import com.atlassian.jira.issue.customfields.option.*
import com.atlassian.jira.issue.util.*
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.search.SearchQuery
import com.atlassian.jira.bc.issue.search.SearchService
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchService = ComponentAccessor.getComponent(SearchService)
def issueManager = ComponentAccessor.getIssueManager()
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser() as ApplicationUser
def query = jqlQueryParser.parseQuery("project=JAYATP") // Add JQL!!
def results = searchService.search(user, query, PagerFilter.getUnlimitedFilter())
results.getResults().each {documentIssue ->
def issue = issueManager.getIssueObject(documentIssue.id)
def field = ComponentAccessor.customFieldManager.getCustomFieldObject("customfield_23400") // change XXXXX with CF ID
def fieldConfig = field.getRelevantConfig(issue)
def Collection targetValues = []
for(val in issue.getCustomFieldValue(field)) {
    if(val.toString() != 'None') {
        targetValues += ComponentAccessor.optionsManager.getOptions(fieldConfig)?.find {
            it.value == val.toString()
    } else {
            it.value == 'M3'
ModifiedValue mVal = new ModifiedValue(issue.getCustomFieldValue(field),targetValues)
field.updateValue(null, issue,mVal, new DefaultIssueChangeHolder())
issue with this line: ModifiedValue mVal = new ModifiedValue(issue.getCustomFieldValue(field),targetValues)
[Static type checking] - Cannot call com.atlassian.jira.issue.ModifiedValue#<init>(java.lang.Object, java.lang.Object) with arguments [java.util.Collection<com.atlassian.jira.issue.customfields.option.Option>, java.util.List<java.lang.Object>]
SERVER
VERSION
9.4.5
Read the story
