Bulk delete Issues cloud Kanban project 2024
David Thomson
February 11, 2024 edited
In Scrum project you have the backlog where you can select multiple Issues and bulk change.
Not seeing anything similar in Kanban, and not seeing any relevant and current documentation.
John Funk
Hi David,
You can run a query/create a filter.
Then from the filter area, click the 3 dots menu in the upper right and choose Bulk Change.
David Thomson
Good morning John, I appreciate that, thank you
Like • John Funk likes this
Ignacio Aredez GenAI Expert
Banned
February 11, 2024
Go to Advanced Issue Search: Use "Issues" > "Search for issues" from the top menu.
Search for Issues: Use JQL to find the issues you want to delete, e.g., project = YOURPROJECTKEY.
Bulk Change: Click "Tools" > "Bulk change all X issues" above the search results.
Select Issues: Check the boxes for the issues you wish to delete, then click "Next".
Choose 'Delete Issues': Select the "Delete Issues" operation and proceed by clicking "Next".
Confirm Deletion: Review your selection and confirm the deletion. This action is irreversible.
Ensure you have the necessary permissions to delete issues. Remember, deletion is permanent, so review your selections carefully before confirming.
David Thomson
Found it - Issues, Search, three dots on right, bulk change all issues
Help us plant more trees
