I am looking for a way to delete issue links of a particular type from a huge number of jira issues. Few of the issues have more than 2000 links.
I am using the below automation rule but this get stuck in In progress probably due to large number of links.
Any better solution/workaround to handle this would be great to know.
I also did not find an API that bulk deletes links from issues.
You can use the API, see api-rest-api-3-issuelink-linkid-delete
Still this will have a limit as well, its not specified.
I tried that but I get this error despite having admin permission. Also, it is not mentioned which project is it referring to? I see nothing under "Body".
No it requires you to have "Link issue permission" on each project in Jira.
So you need to be in the administrator role on each project in Jira.
