Bulk edit shared permission groups in shared Dashboards JIRA
Avinash
I looking to bulk add/replace groups in shared dashboards. We are migrating our old groups to new groups and we would like to modify the permissions in shared dashboard so as to add the new groups. Is there any API call or groovy script which can help achieve the functionality. The current version is 7.10 jira.
PD Sheehan
April 26, 2019
I don't have a ready script ... but you'll want to consult
The services can be reached with
def searchRequestService = ComponentAccessor.getComponent(SearchRequestService)
def portalPageService = ComponentAccessor.getComponent(PortalPageService)
Alex Christensen
July 30, 2019
@PD Sheehan and @Avinash - I'm trying to do this myself, but having a little trouble with dashboards.
It seems that the SearchRequest class has methods for .setPermissions() and .setOwner(), but the PortalPage class does not have these same methods. Since that's the case, I've figured out how to update filters (SearchRequest) using the SearchRequestService interface successfully, but I'm not having the same luck with the PortalPageService interface.
Do either of you have any pointers on what other options there might be, or if I'm missing something glaring in the javadocs?
PD Sheehan
July 30, 2019
You might want to check out the PortalPage.Builder
I just created this on the fly on scriptrunner console... and it works:
import com.atlassian.jira.bc.portal.PortalPageService
import com.atlassian.jira.issue.search.SearchRequest
import com.atlassian.jira.bc.filter.SearchRequestService
import com.atlassian.jira.portal.PortalPage
import com.atlassian.jira.sharing.SharedEntity.SharePermissions
import com.atlassian.jira.sharing.SharePermissionImpl
import com.atlassian.jira.sharing.type.ShareType
import com.atlassian.jira.bc.JiraServiceContextImpl
def user = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def serviceContext = new JiraServiceContextImpl(user)
def sharePerm = new SharePermissionImpl(null, ShareType.Name.GROUP, "myGroupName", null)
def sharePermissions = new SharedEntity.SharePermissions([sharePerm] as Set)
def portalPageBuilder = new PortalPage.Builder().permissions(sharePermissions).name("test portal page").owner(user)
def portalPage = portalPageBuilder.build()
portalPageService.createPortalPage(serviceContext, portalPage)
PD Sheehan
July 30, 2019
Alex Christensen
July 31, 2019
Thanks for the examples, @PD Sheehan !
It seems that PortalPage.Builder() is for creating a new dashboard, not for updating/editing an existing one. Is there no way to set or change permissions on existing dashboards programmatically?
PD Sheehan
July 31, 2019
I had a quick try with getting a new builder based on an existing dashbaord then updating it. I'm currently getting a validation error without explanation (and have no time to investigate), but that may get you in the correct direction.
def sharePerm = new SharePermissionImpl(null, ShareType.Name.GROUP, "qad.com", null)
def originalPortalPage = portalPageService.getPortalPage(serviceContext,15460 )
def isFavorite = portalPageService.isFavourite(user,originalPortalPage)
def portalPageBuilder = new PortalPage.Builder().portalPage(originalPortalPage).permissions(sharePermissions).name("updated name for testing")
def updatedPortalPage= portalPageBuilder.build()
assert true==portalPageService.validateForUpdate(serviceContext, updatedPortalPage)
portalPageService.updatePortalPage(serviceContext, updatedPortalPage, isFavourite)
Like Alex Christensen likes this
Alex Christensen
July 31, 2019
Thanks, @PD Sheehan ! You did indeed point me in the right direction. Here's the version I got to work for me.
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def context = new JiraServiceContextImpl(currentUser)
def sharePerm = new SharePermissionImpl(null, ShareType.Name.GROUP, "jira-software-users", null)
def originDash = portalPageService.getPortalPage(context, 52900)
def isFavorite = portalPageService.isFavourite(currentUser, originDash)
def portalPageBuilder = new PortalPage.Builder().portalPage(originDash).permissions(sharePermissions).name("updated name for testing")
def updatedDash = portalPageBuilder.build()
assert true == portalPageService.validateForUpdate(context, updatedDash)
portalPageService.updatePortalPage(context, updatedDash, isFavorite)
Like Avinash likes this
Avinash
@Alex Christensen @PD Sheehan  - How do i change the ownership of the dashboard, as we would need to change ownership first to update the share permission right ?
PD Sheehan
November 11, 2019
With the code above , you're bypassing the UI's permission check and going directly against the objects. You don't need to be the owner.
But if your requirement is to change the owner at the same time as you want to change the permissions, you can do that with the PortalPage.Builder()
def portalPageBuilder = new PortalPage.Builder().portalPage(originDash).permissions(sharePermissions).name("updated name for testing").owner(newOwner)
Avinash
@PD Sheehan  - Thanks for the quick reply.
I dont think we are bypassing the check as "def context" is using my username.
It is still complaining that you don't have edit permission even using the owner method.
Error Messages: [You don't have permission to edit this dashboard.] | com.atlassian.jira.bc.portal.DefaultPortalPageService@22fb3c82
PD Sheehan
November 11, 2019
Ah, maybe you're right... but you could always set the context to the owner and change the permissions that way.
ComponentAccessor.getJiraAuthenticationContext().setLoggedInUser(ownerOfPortalPage)
Avinash
@PD Sheehan Sorry to bother you again. How do you define the ownerofPortalPage  ?
PD Sheehan
November 11, 2019
Check the javaDoc.
You should be able to get it from the PortalPage object
def ownerOfPortalPage = originalPortalPage.getOnwer()
Avinash
@PD Sheehan  -  I am still unable to set the user. Following error
Script console script failed: groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.security.JiraAuthenticationContextImpl.setLoggedInUser() is applicable for argument types: (java.lang.String) values: [avinash.prasad.admin]
Possible solutions: setLoggedInUser(com.atlassian.jira.user.ApplicationUser), getLoggedInUser(), isLoggedInUser(), clearLoggedInUser()
PD Sheehan
November 13, 2019
Again... javadoc is your friend (with recent releases of scriptrunner, just press ctrl-j on the method that's failing). setLoggedInUser in this case.
You will arrive here: https://docs.atlassian.com/software/jira/docs/api/8.5.0/com/atlassian/jira/security/JiraAuthenticationContext.html#setLoggedInUser-com.atlassian.jira.user.ApplicationUser-
Where you will see that you need to specify an "ApplicationUser"
But the getOwner() returned a string.
So you need to get the ApplicationUser that matches that username string.
def portalPageOnwerUser = ComponentAccessor.userManager.getUserByName(ownerofPortalPage )
Avinash
@PD Sheehan  - Thanks for the information. I have observed one more thing the update removes the current shared permission. Can we change the update to retain the previous shared permission ? For example abc dashboard is shared with project abc and I update the dashboard using the script then the abc dashboard has only the new group and the previous shared element is lost. Is there a way for us to retain the previous one ? Thanks again.
PD Sheehan
November 14, 2019
Can you share your full code?
Avinash
Using same code alex shared. @PD Sheehan
import
PD Sheehan
November 15, 2019
So this script is changing the permissions from whatever the old dashboard had to a newly created permission set consisting of only the jira-software-users".
If you want to ADD to existing permissions, you need to first extract the permission set from the original dashboard and add the new permission to the set.
def originPermSet = originDash.permissions.permissionSet
def sharePerm
def newPermSet = originPermSet + sharePerm
def sharePermissions = new SharedEntity.SharePermissions(newPermSet)
marius.erlenbruch July 30, 2020
Sorry for hijacking this thread, but I was searching for the same solution. The script would fit perfectly for what I try to achieve but I get some errors when testing it.
I don't use Scriptrunner. We don't have this plugin. We have the "Jira Scripting Suite JSS" that is also using the Jira API.
When I try to import some of the classes I get this error:
No module named PortalPageService
I get the error for several other classes, too. So it looks like those are not available. Is there a way to find out which classes I can use?
Oliver Vokoun
November 24, 2021
first of all thx a lot - helped me!
any chance to let me know how to do this for all dashboards at once?
regards
PD Sheehan
November 24, 2021
You can't do this to all dashboard at once, but you can loop through all dashboards and do it one at a time
This uses the search method which is paged by default to prevent strain on the system. My example below only returns 100 pages starting at page 0 with an empty search parameter. You could do this multiple times, 100 pages at a time, or try larger numbers or even add some search parameters to filter the list.
import com.atlassian.jira.sharing.search.SharedEntitySearchParametersBuilder
def params = new SharedEntitySearchParametersBuilder()
portalPageService.search(context,params.toSearchParameters(), 0,100).results.each{portalPage->
//do stuff to the portalPage
Oliver Vokoun
November 25, 2021
Hey Peter, thx for your response..
as far as im new to scripting..
its possible to go over all dashboards, dont delete any other permissions and replace the "any logged in User" with a specific group like company_users?
450 dashboards..
regards
PD Sheehan
November 25, 2021
You can try something like this (untested):
import com.atlassian.jira.sharing.type.ShareType.Name
import com.atlassian.jira.sharing.rights.ShareRights
import com.atlassian.jira.portal.PortalPageManager
def portalPageManager = ComponentAccessor.getComponent(PortalPageManager)
def currentUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def shareGroup = 'company_users'
def groupPerm = new SharePermissionImpl(Name.GROUP, shareGroup, "", ShareRights.VIEW)
def searchParams = new SharedEntitySearchParametersBuilder()
portalPageService.search(context, searchParams.toSearchParameters(), 0,100).results.each{portalPage->
//only process dashboard shared to "logged in user"
if(portalPage.permissions.permissionSet.any{it.type == Name.AUTHENTICATED}){
//this is all the current permissions
def originalPermSet = portalPage.permissions.permissionSet
//we exclude the "logged in user" permission
def newPermissionSet = originalPermSet.findAll{it.type != Name.AUTHENTICATED }
//app the group permission
newPermissionSet.add(groupPerm)
//convert to a SharedPermissions object
def perms = new SharePermissions(newPermissionSet)
//create a new instance of the portalPage with the new permissions
portalPage = new PortalPage.Builder().portalPage(portalPage).permissions(perms).build()
//store the updated portal page
portalPageManager.update(portalPage)
Like # people like this
