Bulk workflow change
İclal Aslan
I have over 400 project, all of the project workflows and schemas are seperate, is there a way I can bulk add a transition to all of the workflows?
Dick
October 10, 2024
Hi @İclal Aslan
Believe me, it's the one thing that keeps us from the cloud: the sheer freedom of projects to define their statuses.
We just had a similar cry-out from @Denis Roussel here in this community
Both @Rudy Holtkamp and myself chimed in to alleviate the workflow woes described there.
Hope you find some relief there,
Dick
By voting for helpful posts and marking answers to your question, you're helping people with similar questions find a solution more quickly. Sharing is caring applies to knowledge as well :)
İclal Aslan
Hi @Dick thank you for responce , It's sad that it is not avaible. But thanks for clarifying.
Like Dick likes this
John Funk
October 10, 2024
Hi İclal,
As you are probably realizing, 400 workflows in a Jira instance is not something that is maintainable. I suggest you begin the process now to identify a handful of common workflows as much as possible and then begin to replace the existing workflow schemes with the new scheme. This, too, will be a manual process.
Also, you should begin the process of creating a "template" project that uses the common schemes. Then create new projects based on this existing project.
İclal Aslan
thanks you are right about common flows. hope we can change soon.
Like John Funk likes this
Cristian0791
October 10, 2024
Hi İclal,
Unfortunately there is no out-of-the box functionality for this.
Maybe you can do this via plugins: ScriptRunner.
Hope this helps.
İclal Aslan
thank you!
