On the burndown chart there is a dropdown option to select meassure of Story Points, Remaining Time Estimate and Original Time estimate.
It's also adding number fields from our custom fields which is not of much use.
Is there a way to stop them showing up?
I've tried setting the field config to restrict access to their project.
I think this is the default behavior. They allow you to use any number field in JIRA for your estimation on a scrum board. I dont see a way to turn that off unfortunately.
Has this changed at all? I definitely do not wanting my custom numeric fields showing up in my burndown report.
