Business hold status in workflow
Madhuri Latha Bhumireddy May 28, 2024
In Jira, when a workflow status like "Business Hold" is set, it should reflect the state where the issue is put on hold.
is there is solution for this.
Trudy Claspill
May 28, 2024
Hello @Madhuri Latha Bhumireddy
The Status field for an issue can reflect only one value.
If you have an issue that is in the status "In Progress", and you change the Status to "Business Hold", then "Business Hold" is the Status that will be shown for that issue.
If you want to keep track that the issue was in the "In Progress" status, you will have to record that in a separate field using either a workflow Post Function or an Automation Rule.
Alternately you can use something other than the Status field for noting that the issue is in a "Business Hold" state, such as a Label, or another customfield.
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
