CSV Import Unable to Import SubTasks as Issue ID no longer available to map to
Steindl_ Calman August 19, 2024
I regularly bulk import a template of tasks/subtasks in my jira project.
My CSV file has the following:
Summary,Issue Type,Issue id,Parent id,
test1,Task,1,,
test2,Task,2,,
summaryname subtask A,Sub-task,,2,
summaryname subtask B,Sub-task,,2,
This used to successfully create two SubTasks beneath the "test2" Task.
This has recently stopped working for me as when i go into the import menu; in the mapping fields page; the "Issue ID" field is no longer available to map to.
Thus, when i do the import, the subtasks do not get created as the parent Issue ID was not imported.
I am unsure what to try next; everything i have found says my csv file has the correct structure and I havent actually changed anything. Was there an update recently for Parent relationships in JIRA?
Any suggestions how to bulk import Tasks AND SubTasks simultaneously in JIRA cloud now?
Validation Test Results
Other Information;
Jira Project is  company managed, software project.
I am using the CSV import from the Filter/Search screen menu.
Luka Hummel - codefortynine
Hi @Steindl_ Calman
If you are willing to use a third-party app, you could try our app Deep Clone for Jira to replace your CSV templating process. With Deep Clone for Jira, you can clone a template project including settings and issues, even to other Jira instances.
You can find more details on how to use Deep Clone for templating here.
This could help you streamline your import process and overcome the current limitations you're experiencing with the standard CSV import method.
Samuel Gatica _ServiceRocket_
Hi @Steindl_ Calman
Try going to Settings > System > External System Import and do the import through that path instead of through the Filter/Search function.
Also, If you are trying to import Sub-tasks where their parents already exist, you do not need to import those parents as well. You only need to have an empty "Issue ID" column.
Example:
Parent Id, Issue Id, Summary, Issue Type
ABC-123,,"This is the summary",sub-task
ABC-123,,"Second subtask",sub-task
Yu can leave the "Issue Id" column empty.
Hope this helps
Best regard
Sam
Steindl_ Calman August 21, 2024
Hi Sam,
Thanks for your answer!
To clarify; I am trying to import new Tasks and new SubTasks.
(so they don't have ABC-123 numbers yet).
I am in a company managed JIRA project. This is what i get when I click on Settings.
Is there a different settings menu I am meant to be using?
Hi @Steindl_ Calman
Please check this post import a list of issues including sub tasks in one import
See Import data from a CSV file
I'm not sure the sub-task section is too well written, as a lot of people seem to struggle with it, but this is a less fussy example of a file that will create 5 issues, two tasks, and 3 sub-tasks:
summary, issue id, parent id
story1, 1,,
subtask-1-1, 4, 1
story2, 8,,
subtask-2-1, 16, 8
subtask-1-2, 32, 1
Note that the issue id will be imported into "external id" as well, and the "parent id" is not imported directly, because it's only used to make the parent/sub-task link. Also, you'll need some other columns for issue type etc. I really did build that file to show you the parent/sub-task structure, nothing else
Hope this helps!
Best regards
Sam
