CSV import issues - document type error
Pedro Miguel Simões Neto
September 19, 2025
Whenever i try to import issues from CSV, the validation process always shows the error "document type required". I save the file as CSV UTF-8, how to fix this?
Marc - Devoteam
September 19, 2025
Hi @Pedro Miguel Simões Neto
Welcome to the community.
Can you provide more context, where and how are you trying to import issues into Jira?
Screenshots are useful, as well as the structure of your document.
Harpreet
September 20, 2025
Hello @Pedro Miguel Simões Neto
When you encounter the "document type required" error while importing issues from a CSV file into Jira Cloud, it typically indicates that there's an issue with the CSV file format or its contents.
Check the CSV Format:
Make sure your CSV file is correctly formatted. Each column should have a header that corresponds to a field in Jira. Common headers include "Summary," "Description," "Issue Type," "Priority," etc.
Ensure Proper Encoding:
You've mentioned saving the file as CSV UTF-8, which is correct. Double-check that your file is indeed saved with UTF-8 encoding, as other encodings can cause issues.
Check for Special Characters:
Ensure that there are no special characters or commas within your data that could disrupt the CSV format. If your data contains commas, enclose the fields in double quotes.
September 23, 2025
all of that was done, the error keeps showing up
Valerie Knapp
Hi @Pedro Miguel Simões Neto , welcome to the Atlassian Community and thanks for your question.
Could you please share a screen of where you are getting this error in the wizard / External System Import section? You can obviously anonymise the screen to remove any sensitive data. I am just not seeing this 'document type required'.
Best wishes
