Hello All,
I m using jira cloud. I would like to import 2 issues into Jira. The 3 issues have all the required filed as well as label as one of the field.
I have csv file containing 2 issues with labels. The values of label for each issue are
Test Module 1
Test Module 2
While importing the csv the following error appears.
Issue can't be created due to the error/s [The label "Test Module 1" can't contain spaces]
Issue can't be created due to the error/s [The label "Test Module 2" can't contain spaces]
1) I tried adding the labels between single quote / double quotes in the csv file. The same error is displayed.
2) The word "Test Module 1" is a single label, not multiple labels.
3) If the label is changed to "Tes-Module-1", the import works properly.
Please suggest how to import labels with spces.
Santhosh R. Bhat
Hello @Santhosh R Bhat
Spaces are not allowed in Labels values at all, even if you enter the values directly in the UI.
You need to use dashes or underscores instead of spaces.
[ and ] are not allowed either.
Colons are a valid character but will cause the labels not to appear in the autocomplete text. JQL searches for labels with colons seems to work though.
Equals (=) seems to work
There is also a limit of 255 characters for a label
Help us plant more trees
