Calculate Currency Field
Darko Jozipovic January 15, 2025
I have a currency field in Jira that I would like to calculate The result of currency field 1 + 2 should be inserted into currency field 3. What options do I have via automation or script runner? Or is there a possibility to realize this
John Funk
Hi Darko - Welcome to the Atlassian Community!
You should be able to do this with a simple automation rule.
Take a look at this post to see if it helps.
https://community.atlassian.com/t5/Jira-questions/Using-Automation-to-Sum-multiple-custom-fields/qaq-p/1957161
Unfortunately I can't select the field to edit in the automation because it is a special currency field.
John Funk
Are you using an add-on app for the field? If so (and I suspect you are) what app is it? Have tried to contact their support?
Yeah i am using a add inn ( Fields - Custom Field Types for Jira)
John Funk
So, what app is that?
John Funk
I suggest you contact the vendor for support then.
January 15, 2025
Hi @Darko Jozipovic
Adding to John's suggestions...
Sometimes custom fields added by marketplace apps can be accessed in rules using their custom field id, such as {{issue.customfield_12345}} rather than the smart value name.
To learn if your field is supported by rules, please use this how-to article: https://support.atlassian.com/cloud-automation/docs/find-the-smart-value-for-a-field/
And even when a field is supported, it may not be listed in the rule action's dropdown fields.  In that case, please use a JSON expression to update the field: https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/
Like • John Funk likes this
Register today
