Boa tarde,
Alguém que usa o Jira em português (BR) poderia me ajudar, estou com um problema em um dos apps que eu uso:
The issue couldn’t be created because the “Labels” field is missing from the project’s field configuration.
Eu procurei na internet e descobri que o campo Labels não existe no meu projeto, existe algum outro nome para esse campo em português? Como eu faço para criar esse campo e resolver esse problema?
Hello, Good day. Either label field is set as required or the field is configured in validator (workflow). Good to Project settings >> Issues >> Screens and add label field to issue create screen. Thanks
Sorry for the delay to respond, I got in the place you pointed me to, but the field labels doesn't apear to be put in
Hello, Good day. Go to project settings >> Issues >> Fields >> select 'Edit' and search for 'Label' and attach a screenshot like below.
Hi, here is the print you asked, there is nothing in there.
Hello, Good day. Could you share a screenshot where label is showing required while creating the issue? Thanks
The filed labels is not required to create a issue, it is required for a app that I have to work, the apps is Chat for JSM, and when I try to open a chat on my Help Center it always show that it can't because the field labels doesn't exist, but it still goes throught and creates an issue.
Got it, thanks. Please create this issue on the following JSM community portal as well : https://community.atlassian.com/t5/Jira-Service-Management/ct-p/jira-service-desk
