Can Automations be used to generate a standard set of tasks and sub-tasks?
Si Walker November 5, 2024
I am trying to automate the generation of a standard set of tasks and sub-tasks that will run once a new Epic is created in Jira Cloud. Is that possible without adding a marketplace app?
I have created an Automation but when it runs, the Tasks are not nested under the Epic and none of the Sub-Tasks are created either.
Dick
November 5, 2024
Hi @Si Walker , welcome to the Atlassian Community!
Yes, automations can generate fully filled tasks and sub-tasks for you, when an epic is created. You wouldn't need a marketplace app.
You can "nest' tasks under an epic by setting the epic link field to the newly created epic key.
Hope this helps,
Dick
Dick
November 5, 2024 edited
Hi Si
it's all in the Create Issue step where you link the task to the epic. Using the dropdown with the <Cog icon> Choose fields to set, you can select multiple fields to fill. Check the Epic Link entry in the dropdown, and you can fill it with the Current issue reference as depicted below:
Si Walker November 6, 2024
Thanks Dick - that works like a charm! However, I used Parent intead of Epic Link as the dialogue box suggested that it will supersede Epic Link at some point.
Many thanks for your help, very much appreciated.
Like Dick likes this
Dick
November 6, 2024
@Si Walker
It's true, this quarter Atlassian has scheduled work on homogenizing the child parent relationship across all issue types using the parent link field. It's way more cleaner than maintaining the odd-one-out epic link field that I still have to use (we're running an older Long Term Support version of Jira datacenter)
Thanks for marking the question, it makes finding answers easier for people with a similar question.
Dick
Like Si Walker likes this
Thanks @Ponnappan Ganapathiya  and @Dick
Here's how I currently have it set up which creates a Task and each of their sub-tasks but it isn't created within the newly created Epic. Any ideas?
I am sorry, You want to link the task with epic?
Did you try this?
While creating task edit the Epic link field.
Thanks, really appreciate your help and advice.
We use Jira Cloud more like a project management tool so on each Jira software project board (we have several) there may be 100+ Epics but each of these Epics needs to have an identical set of tasks and sub-tasks.
A User will create an Epic and give it a specific, unique title. What I want the automation to do is trigger when the Epic is created and automatically populate it with the tasks and sub-tasks.
At the moment, the automation triggers when the Epic is created but it doesn't populate that Epic with all the tasks. The tasks it does create do not have a Parent.
Does that make sense.
@Si Walker
From your reply, I understand the task is created but not linked with the Epic!!!
https://confluence.atlassian.com/jirakb/epic-name-vs-epic-link-779158632.html
This epic link field connects between Task and Epics. If you add this field to Task create screen you can set the value as trigger issue, which is the Epic that trigger that rule. Hope this should work.
Register Now
