Can Gadgets label names can be edited
Harish Kumar July 25, 2023
Hello Team,
I have created a dashboard for issue statistics and recently created chart. I want to edit the gadget label names. Could you kindly help me with the steps to follow to do the same.
Kai Becker
Hi @Harish Kumar
welcome to the community and thanks for your question.
It is possible to rename the gadgets using the following steps:
  1. Edit Dashboard
  2. hit the three dots on the right side of the gadget and then Rename
  3. Edit the name and save the dashboard and your gadget is renamed:Screenshot 2023-07-25 at 14.33.36.png
Harish Kumar July 25, 2023 edited
@Kai Becker : Thanks for your suggestion.
When i tried clicking on edit dashboard i do not see the above screen without any options to change the gadget name. could you kindly help.
Kai Becker
@Harish Kumar you selected jira-cloud as a tag, but considering your screenshots you are using the onprem version.
That being said, the onprem version of Jira does not allow to edit the gadget name. Sorry 😕
Like • Harish Kumar likes this
@Kai Becker : Thanks for the inputs. Thanks for quick help
Register today
