I have set up a custom email notification to send emails upon a specific state transition. I want this notification to go to a distribution list. It seems emails are received when I pass individual email address, but emails are not received when I pass a distribution list.
The field I use to pass the distribution list is called "To addresses".
Also can a DL have its own sub DLs. Will that cause any issues?
Any help would be appreciated.
There isn't a difference between a DL and individual email from JIRAs perspective. This is all handled by the receiving mail server.
If the email is not getting received I suggest you check the following:
image2016-3-10 11:0:19.png
in case you see any related errors please post them here
Peter T
Thanks for your response Peter. Another piece of info is that our JIRA is integrated with outlook distribution lists (groups). But before a DL can be referenced within JIRA it needs to be added to JIRA first. I wonder if that is the case since I cannot see the DL from our Jira. I have asked our IT department to add it.
I think that is the case!
Double check you are using the SMTP address of the DL. I don't see why this wouldn't work. Maybe ask your exchange admins if it's being blocked, or if the user doesn't have permission to send to that DL.
Save your spot
