×When a task is created, I want the reporter field value copied over to the impacted user. Can I do this with Automation for JIRA?
Hi Saskia,
Yes you can certainly copy a user field across on create. Here's an example rule:
So I simply used the edit issue action to set the 'Reviewers' user custom field (in your case this would be 'Impacted user'). The trick then is to use a smart-value to set the reporter. Simply type this in the field:
{{issue.fields.reporter.key}}
When the rule executes, this will be evaluated to be the username of the reporter of the issue that was created. Hope that helps!
Andreas
I am trying to do something similar. I need to take the child value from a custom Cascading Select List and copy it to the Application Name field when the issue is created.
FYI I am a novice when it comes to Automation. When I search for the Cascading Select List 1 I am unable to find it in the Choose Fields to set section.
thank you
Robert
Hello @Robert Carey ,
Did you find your solution I need to implement the same thing but could reach it so far ?
- which plug in do you use fro cascading select ?
- I need to fillup the summary field with all value from each cascading select field
regards
I am looking for help with JSON to do similar - split a custom cascading field into two customer text only fields so that I can pull them into Advanced Roadmaps and reports. Anyone can help?
Hi @andreas ,
I am facing issue when i am trying to copy value of manager field to Approvers field in jira cloud automation.
I am not bale to do so by using below smart values, could you please suggest the right method. it would be of great help.
"fields": {
"customfield_15601": [{ "id": "{{issue.CustomField_15806.value}}" }]
Note : My manager field holds value from user property field (key:value)
Vinod
