Sign up Log in
Can I have two statuses per one column in Jira nex-gen project
Lilit Grigoryan October 14, 2019
Hi
I am using a Kanban board
I want to add one more status for an already existing column. To explain, I have a To Do column and Want to have To Do and More Work required statuses and both statuses should make the ticket appear in the To Do column
Lilit
Jack Brickey
October 14, 2019
Hi Lilit,
well not exactly. You can't do this in the default NG board but you could choose to create a custom Kanban board and map the NG statuses to the columns of your choice. Note that this type of kanban will not be directly associated with your NG project. Rather you must create the board setting the Location to your profile rather then the NG project. Then you can add a link to that board in the sidebar of your NG project. LMK if you have questions.
