in the Administration area -> Issues -> Priorities
I want to insert a hyperlink as a Description, but it doesn´t render it.
Do you have any solution to fix that?
Hi @Lara Weber
Welcome to Atlassian Community,
Go to project > Settings > Fields and click on Edit icon on top right.
It will navigate you through field configuration scheme. Find priority and click on Edit link next to it.
Then type your html as seen in the image below
Hi @Tuncay Senturk _Snapbytes_
Thanks for your answer! I wanted to add an hyperlink in Description field below, but the translation does not work.
Is there any hack to fix that?
Thank you for your help!
Oh sorry, I supposed that you were mentioning the description of Priority field, not the priority items' translation.
Here is the sample
I do not know a solution to display each priority's description. Sorry
Register now
