I have a similar question to the one asked here:
I don't see that the question was answered at the end. So to ask it again, can I integrate google form responses with jira or have any sort of form i can send to stakeholders and receive its output on JPD?
Great question—there’s definitely some confusion around this topic.
Direct integration between Google Forms and Jira Product Discovery (JPD) isn’t available out of the box.I think you’d need to set up something custom using Google Apps Script, webhooks, or third-party automation tools like Zapier.
If you need a shareable, user-friendly form to collect inputs from stakeholders and automatically create Jira Product Discovery ideas, Smart Forms for Jira is a solid alternative:
📬 Send the form via email, website embed, QR code — you can sey up access to - no Jira login required
🧩 Map form fields directly to JPD idea fields (summary, description, custom fields, etc.)
✅ Automatically creates ideas in your JPD project upon form submission
📊 Built-in analytics to track submissions
It’s a simple way to collect structured input from stakeholders, customers, or internal teams without workarounds.
Let me know if you’d like help setting this up—it only takes a few minutes to configure! 🚀
