Can I make Work Description box required?
Dmytrii Tykholaz September 21, 2024
While logging time, team usually forget to add a description to their worklog. However, these comments are needed for managers.
Is there a way to make this worklog description field required?
4 votes
Nikola Perisic
Hello, welcome @Dmytrii Tykholaz
Yes, there is a possibility to do this by changing the field configuration for the Description field making it Required. You would go to Settings > Issues > Field Configuration. Find the Description field and click on Required. After that, click on FIeld Configuration Scheme and create a new scheme and apply the the field configuration you've created.
After this, you need to apply it to your project, by selecting Project settings > Issues > Fields and changing the field scheme.
Thanks for reply.
Sorry, probably I didn't made it clear. I meant a 'Work description' field - please see the screenshot:
Nikola Perisic
In this case, this is not possible, since this is actually hard coded, and this is not given as an option for field configuration.
@Nikola Perisic , thanks for explanation!
Help us plant more trees
