Can I prevent users from cloning issues on a specific project?
Mohamed Alaoui December 8, 2017
I am building a project which will be used internally for Code Releases i.e. this will not be a typical Software Development project. I want to prevent users from cloning issues, is it possible to do this for this project only?
6 votes
Ignacio Pulgar
December 8, 2017
You can potentially do it by applying this property to all workflow steps used by the project:
jira.permission.create.clone.denied
Ensure the workflows in which you add this property are not used by any other projects; otherwise the clonation would be forbidden in other projects too.
Mohamed Alaoui May 16, 2018
This does work and must be applied to all statuses on that workflow. Luckily, in my case, this was a small project that was using it's own workflow so this worked perfectly.
Mo
Like • Karoline Rezende Ramos likes this
PS May 20, 2020
Hi @Ignacio Pulgar
In my software project, we have given access to 'Anyone' to create issues. If I need to restrict 'clone' option to 'Anyone'. What should I enter in Property.
Please suggest
Ignacio Pulgar
May 20, 2020
Hi @Sreekala Dande ,
For not allowing the creation of clones to Anyone, you need to add a property which allows the creation of clones just to users with either a role in the project, or a jira group.
Probably, your use case should be better covered with roles, so this is the property you need to add on all statuses of your workflow, specially the initial status (please, see JRASERVER-62200 for more info on this subject).
jira.permission.createclone.projectrole = 10300
Where 10300 is the id of the project role you would like to retain the ability to clone issues.
As far as I've tested, both createclone and create.clone are valid and equivalent syntaxes.
You may find the id of a given project role in the URL shown after clicking on its Edit link, on the Project Roles Browser.
First, go to https://YOUR_JIRA_BASE_URL/secure/project/ViewProjectRoles.jspa
Click on Edit and see the id of a project role, in example Administrators:
As you are likely to need to enable the creation of cloned issues to more than one project role, then you will need to add a numerical suffix at the end to make each property unique, like this:
You may also learn more about the usage of workflow properties by visiting this article.
Hope it helps.
Like • 2 people like this
Tim Jedlicka
https://confluence.atlassian.com/jirakb/how-to-restrict-issue-cloning-in-jira-1087510102.html does a very good job of describing why this is a hack (and why "createclone" and "create.clone" and in fact "create.foo.bar" all "work" the same).
Apparently Atlassian acknowledges this method is a hack and apparently has no intention of adding a feature to officially restrict cloning of issues.
SCK March 16, 2022 edited
The key used here, jira.permission.create.clone.denied, is invalid, and JIRA is just throwing a valid error:
Unknown type 'clone' in meta attribute 'jira.permission.create.clone.denied'. Valid permission types are defined in permission-types.xml
Using the right key, jira.permission.createclone.denied, the problem shouldn't happen.
As stated in bug 59487
Jeffrey Bistrong
December 2, 2024
your solution worked for me in jira cloud thanks!!!
Newthon Junior
I´m using Jira Cloud in a Company-managed project and the property
Didn´t work for me (didn´t received an error but I was able to clone issues in the In Review status.
The property jira.permission.createclone.denied didn´t worked too.
It is unbelievable (well, not so unbelievable if you see how much complains Atlassian has related to critical features don´t implemented) that Jira doesn't have a way to forbidden Clone permission.
How to restrict issue cloning in Jira | Jira and Jira Service Management | Atlassian Support
Robin Surland
You can take away rights for them to create issues, but cloning is not an available action to be controlled in permission schemes.
Newthon Junior
How to restrict issue cloning in Jira | Jira and Jira Service Management | Atlassian Supportwf.jpg support.atlassian.com
