Can Icon colors be customized by projects for easy identification ?
Naresh Rajak November 8, 2024
Our organization recently started using JIRA. One of the users asked if
icon colors can be customized by projects for easy identification ?
Thank you
Naresh
Michael Yaroshefsky - Visor for Jira
Hey @Naresh Rajak welcome to Jira and the Atlassian Community.
I don't think it's possible to change the default icon colors, but you can create your own custom icons for issue types, by going to:
Project Settings >
Issue types
then click on the Icon you want to change and select "Upload a photo"
You can also change icons centrally (for all your projects) following these instructions:
https://confluence.atlassian.com/jirakb/how-to-change-the-icon-for-issue-types-1141997212.html
Hope that helps!
Thank you @Michael Yaroshefsky - Visor for Jira . Users are happy now that they can easily distinguish.
Harrison Ponce
Hi @Naresh Rajak , that's a great question! When you talk about the icons, do you mean the issue icons (e.g., story, task, sub-task, epic, service request, bug, etc.)? A picture of an example would be awesome, too!
