My organisation is looking at adopting JIRA and I am researching Zephyr for JIRA as a potential Test Management tool. In our current solution, a Test Case cannot be executed until its Status is "Ready", therefore it can't be executed if it is in Draft, Requires Review or Changes Needed statuses.
If workflows are enabled for Tests, does Zephyr provide similar functionality?
Hello Sarah,
Tests can be a simple or complex issues with a lot of detail, steps, links and files associated with them. Zephyr allows to enable workflow for tests facilitating to close the testcase if they are invalid/covered/done instead of deleting them by changing the status. But the Execution option will be available for all the statuses of the Test, that means once a test has been created the next logical thing to do is to excute it.
Kind Regards,
Swapna Kumar Vemula.
Hi Swapna - thank you for the comprehensive answer. This would be of great benefit if it was implemented, I hope your Product Management team agrees.
For my client this would be useful because they want to prepare the test before starting the execution. The test have a review workflow.
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
