Can a custom field be updated through a workflow transition
s
Hi
My question relates to a custom field that requires editing when a workflow transition is processed.
 Is this possible
Regards
Showkat
Udo Brand
January 20, 2015
Yes, that is possible. First you need to add a screen with that custom field to that transition. Secondly you need to add a validator (field required validator) in that transition that says "there must be a value in that field".
Udo Brand
January 20, 2015
For the field required validator you would need to enable JIRA Suite Utilities Plugin (if not already done)
Udo Brand
January 20, 2015
Or if there is already a value in that field and it must be changed during that transition, use "Field has been modified" validator from JIRA Misc Workflow Extension plugin.
s
Hi - Thanks for the feedback. The option "field required validator" - is not available - only field modified - and single value validator. Regards
Udo Brand
January 20, 2015
You need JSU Plugin for Field Required validator, see my first comment. But Field Modified will do as well.
