I'm trying to pull a CSV file with the dump of all projects listed under my site, however, I'm not certain of how to proceed further.
Any help on this would be appriciated!!!
with API (returns a JSON)
yourjira.com/api/latest/project
with DB
SELECT * FROM project;
Do you get an error? no data are received? have you tried both?
in the API you should add parameter expand=lead
{{url}}/project?expand=lead
In the DB the table project has a field named LEAD with the username of the project lead
Check this link, it should help you to export to csv.
I would do this while running queries for each project, like project = XYZ and then export that project to a csv
