Can i create a DEAP JIRA by API - It says ERROR
Danh Dang May 22, 2020
POST
"fields":
"project":
"key": "{{project}}"
"summary": "DEAP - {{summary}}"
"issuetype":
"name": "DEAP"
"versions":[
{"name":"{{affectversion}}"}
"assignee": {
"name":"{{Assignee}}"
"reporter":{
"name":"{{Reporter}}"
"customfield_10110":{
"name":"{{Developer}}"
"priority":{
"name":"{{Priority}}"
"customfield_10125": "{{Class}}",
"customfield_10126": "{{Module}}",
"customfield_10127": "{{MainComponent}}"
Danh Dang June 2, 2020
Evan Underwood-Harley
June 2, 2020
You can use POST /rest/api/3/issue/{issueIdOrKey}/transitions
You can transition an issue to the Create DEAP option, but you will need to know the transition ID. (which you can get from /rest/api/3/issue/{issueIdOrKey}/transitions)
There is also the option to fill any screens that appear on the workflow transition.
See the Transition issue part of the documentation for further details- https://developer.atlassian.com/cloud/jira/platform/rest/v3/#api-rest-api-3-issue-issueIdOrKey-transitions-post
May 22, 2020
Hi Danh,
This could be a number of things:
- Are the values you are putting into your fields valid? I.e. Is the reporter value a real user in jira with access to the project? Are any of the customfields select fields and you are not using a valid value? Does the issuetype you are using exist? ...etc
- Are there any required fields that you have not specified a value for?
- Are there any conditions / validators  on the project workflow that have not been met? Or any post functions which may be causing issues.
Do you have access to the jira logs to see if it provides more information?
I would first try to create the issue in jira using the exact values your API POST is using and see if that works or you get the same problem.
Regards
Evan
Danh Dang May 25, 2020
thanks, I am looking to that. Do you know If the DEAP can be created by API?
May 26, 2020
Are you referring to DEAP been created as an issue type through the API or something else?
Danh Dang May 26, 2020
I cannot create the DEAP by API for now, and I am not sure this is supported? I not support then please let me know. thanks
May 27, 2020
You can create the DEAP issue type via the API.
using POST /rest/api/2/issuetype
{ "name": "DEAP", "description": "description", "type": "standard" }
See documentation for more details
https://docs.atlassian.com/software/jira/docs/api/REST/7.12.0/?&_ga=2.255600522.388755086.1590482849-973955557.1568640194#api/2/issuetype-createIssueType
Danh Dang May 27, 2020
let me check if this works then i will accept the answer
thanks, I would like to create a JIRA with DEAP type. Not create the Type of DEAP. Sorry for the confusion.
June 2, 2020
Sorry not sure I understand? Do you want a DEAP project via API?
The DEAP project is already created. I just need to create Jira with DEAP type by API (GUI is created successfully). Look like we are not supporting this scenario
June 2, 2020
Can you provide a screenshot from the GUI of what you mean by DEAP type? I can then hopefully be able to assist you further.
    "errorMessages": ["We can't create this issue for you right now, it could be due to unsupported content you've entered into one or more of the issue fields. If this situation persists, contact your administrator as they'll be able to access more specific information in the log file."],
    "errors": {}
