Can i create or clone an issue with a dynamic project key?
Juergen Koeck
So i want to clone or create a new issue with the same data in a different project. just like  this:
But i always get an Error:
Error creating issue
Specify a valid project ID or key (project)
Issue was created successfully, however some unexpected errors occurred -
Is this possible, do i have to do this via a REST Call or is there a workaround?
December 5, 2024
Hi @Juergen Koeck
For a question like this, context is important for the community to help.  Please post the following:
  • what type of project is this (e.g., company-managed, team-managed, etc.),
  • an image of your complete automation rule,
  • images of any relevant actions / conditions / branches,
  • an image of the audit log details showing the rule execution, and
  • explain what is not working as expected.
Until we see those...
I believe the project id value may be provided to create the issue dynamically.  For example:
  • create a variable named varProjectId
  • type {{varProjectId}} in the Project field for the Create Issue (or Clone Issue) action
  • when it appears below the field, select it for use to create the issue
Juergen Koeck
Hi @Bill Sheboy
so here are the Details:
  • Company-Managed-Project
  • Audit Log and all the relevant Details:AuditLog.png CloneIssue.png CreateNew Issue.png GetProjectKey.png
So the cloning and creating a new issue doesnt work.
The Project key is also correct
Marc - Devoteam
December 6, 2024
Hi @Juergen Koeck
If you add a log action after creating the variable and log the content of the variable.
is this a correct project Key, I suspect so by your mention.
But I think the issues is this text and the project option in the clone and create acton need an value, as the project field is not text.
By using these conditions normally, you will start typing and based on your input a project can be selected. This is an ID.
So in you automation you would need to use the variable to find the correct ID of a project and you that as input
Al theoretically of course :)
December 6, 2024
There is an existing smart value named project, and so it is certainly possible the rule is getting confused by your variable name.  I recommend always adding a prefix to variable names to avoid problems, such as with varProjectId
And as Marc and I have described, you must use the project ID and not the project Key to dynamically select the project for issue creation.
Juergen Koeck
Hi @Marc - Devoteam ,
your theory worked exactly like you predicted.
It worked after querying for the correct ID via the Rest API
Like • Marc - Devoteam likes this
Luka Hummel - codefortynine
Hi @Juergen Koeck,
If you are encountering problems with your cloning automation, and you are willing to try a third-party app, you can try our app Deep Clone for Jira. Deep Clone allows you to clone issues across projects, including bulk cloning and adjusting fields dynamically, without needing complex automation rules.
Marc - Devoteam
December 5, 2024 edited
Hi @Juergen Koeck
If you want to clone an issue into another project, you need to specify the project where the issue needs to end up.
This is not dynamically possible.
Juergen Koeck
thanks for the reply,
so i need to make a REST call to clone the issue in another project, which does the exact same thing, except its a bit more tricky?
This should work or am i wrong?
Marc - Devoteam
December 5, 2024
No API can't do this as well.
You need to specify the project key or project name where the clone needs to end up.
This doesn't matter if you use automation or API
You can't use a dynamic project key.
You could make a lookup table in your automation and based on the id from the table you will have a value (set these values as project keys)
Based on if/else options in a rule the issue would get created in the related project.
This can only be done with a manual rule where you ask an input value
Then compare this value with a value from the lookup table
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
