I would like to know if Jira has any option to determine if resources allocated in different projects of the organization have enough capacity.
Hello @Arensa Prasta ,
When you say resources,what exactly do you mean?
I mean resource management: different team members' capacity allocation in different projects. For example: I have a team member whose capacity is allocated in different projects. When I am adding work for him in a project, is there a decent way in jira that notifies me that his capacity doesn't allow it? Or reports that show the % allocated in projects per resource.
I hope i was clear and thank you in advance
Yes,now it is clear. On this page you can refer to the Walter's comment:
Br,
Nikola
Hi @Arensa Prasta
It's Mary from Planyway:)
If you want to get a visual representation I'd recommend you to try Planyway workload feature. It visualizes resource capacity across projects and you can easily balance workload right on the timeline view.
for some reason I am not able to find it in the market place
