Hi, dumb question no doubt, but. I have various test scripts going into BonFire.
I want to use GreenHopper for task management, and reference the BonFire tests associated with each GreenHopper story/task.
With GreenHopper installed (using Scrum), the 'TEST' issue type is not available.
Any help much appreciated.
thanks , James
I'd recommend trying the Rapid Board, it will include the issue types you're after.
Shaun
Thanks Shaun. I now have a bigger problem, or so it seems. Installing GreenHopper has taken over my Issue type Scheme's. I have BONFIRE 2.4 installed also, but there is no issue type of 'TEST', only GreenHopper types, even i the Default scheme (see below).
Obviously I am confussed -I can find no help in the documentation for Jira or BonFire.
Any suggestions?
James
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
