Can it be possible to get Crowd attribute by Scriptrunner
Jason Park
January 16, 2020
I want to manage the value related to user ​in the Crowd attributes and use them in JIRA.
So how can i get attributes value from Crowd using Scriptrunner?
Kristian Walker (Adaptavist)
Hi Jason,
Thank you for your question.
I can confirm that ScriptRunner for Jira Cloud is only able to make calls to the Rest API's which Atlassian provides inside of the Jira Cloud Rest API documentation page located here.
I have looked at this API and can see that there is no API to call Crowd directly but that they do provide the API located here to get a user's properties which may allow you to retrieve the information which you require.
I would advise tho creating a support request directly with Atlassian to ask if there is any other Rest API's which can be used to pull user data from Crowd.
I hope this helps.
Kristian
Jason Park
January 19, 2020
Thank you for your reply.
You mead there is no way to get the Crowd attributes value by Scriptrunner at this moment in time.
i try to find alternative way to manage user related information.
Thank you!
Marcin Kempa
January 20, 2020
Hi @ja
This request is being tracked here https://jira.atlassian.com/browse/CWD-2417.
Would you mind describing your use-case here?
Best Regards,
Marcin Kempa
Read the story
