Can not move issue from sprint to another using board
karim.belhadj
February 11, 2020 edited
Hello team
Im using jira (v6.0.2) , i have many sprints planned , the problem that i have is i can't  move one issue from the active sprint to another sprint .
The solution is to remove the issue from active sprint , so it's come back to backlog , and then i can move the issue from backlog to the other sprint (active or not active)  .
Question  why should i go through the backlog to move issue between sprints ?
Is there any solution to move issue between sprints directly without going throught the workflow .
  1: i can drag and drop from backlog to any sprint .
2 : i can drag and drop from sprint that not starts
3 : but i cant move from active (start) sprint to other sprint only i can remove it to get back to the backlog
Please could you help me , it's the normal behaviour ?
Learn more
